Re: 383 VS 440
[Re: DCM71cuda]
#1017183
06/23/11 07:15 PM
06/23/11 07:15 PM
Posts: 2,177 ill
dennismopar73
ill
....I bet now somebody will tell me that they can build a 340 and outrun a 360......
Re: 383 VS 440
[Re: CUDA8U]
#1017184
06/24/11 11:45 AM
06/24/11 11:45 AM
Posts: 957 Heart of Ohio
4boxers4
Heart of Ohio
Some humorous replies here. First...alot depends upon what YOU want out of your application. I have built both. Many parts are similar. The 375hp versus the 335hp factory rating(which HAS to be pretty accurate because of the way the gov't makes car companies validate their vehicles)...is self explanatory. 40 extra hp to start with just makes it easier(sorry, I live in a 'common sense' world). The 383 is a fine motor, make no mistake about it. It will also rev higher but high revs usually causes more wear on parts.
Persistance is omnipotent
Durability Engineer, Chair and Couch division...
Re: 383 VS 440
[Re: 4boxers4]
#1017185
06/24/11 11:48 AM
06/24/11 11:48 AM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Some humorous replies here. (which HAS to be pretty accurate because of the way the gov't makes car companies validate their vehicles)...
Speaking of funny replies. You are kidding right.
Re: 383 VS 440
[Re: DCM71cuda]
#1017186
06/24/11 12:16 PM
06/24/11 12:16 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
LMAO. But I've built a 340 that outran a 383.
Re: 383 VS 440
[Re: dustergirl340]
#1017187
06/25/11 10:34 AM
06/25/11 10:34 AM
Posts: 1,489 west kentucky
gomangoRTSE
west kentucky
________________________________________________________________ Well some people have built the bigger bore shorter stroke 340 that could outruns 360s. Mostly that was years ago before 340 parts because scarce. For sometime now parts and alternatives have been developed for 360s to produce more power. Its easier to find, purchase and build 360s than back in the 1970s.
As for the 383, Im simply not a fan of the power it produces. Yes it can produce power if stoked. But otherwise based on dollar for dollar money the 440 will produce more power. And I think this is especially true if your working on a working mans budget.
You have your 383 guys who will vehemently defend them and find the exceptions to the rule examples sure, but some would say they would rather stroke a 400 motor than a 383. This I cant speak about, perhaps someone else could address.
Re: 383 VS 440
[Re: CUDA8U]
#1017188
06/25/11 10:41 AM
06/25/11 10:41 AM
Posts: 768 Maryville tn
67coronetman
Maryville tn
My 440 is making 580 hp & 600 ft tq with only 448 cid.! Stock crank & rods with KB pistons. Where i get my power is the Indy heads and TTI headers & comp solid lift cam.
Old car are me......
Re: 383 VS 440
[Re: 67coronetman]
#1017189
06/25/11 10:56 AM
06/25/11 10:56 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
doubt the TTI headers give you any advantage over any other brand of header. But I'm with you I have a stock crank/stroke 440 w/ ported Stage VI heads and a comp 588 solid roller making around the same #'s...maybe a tad more.
Re: 383 VS 440
[Re: CUDA8U]
#1017190
06/25/11 11:10 AM
06/25/11 11:10 AM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
Reading through this thread I found it consistent with past street racing around my area. Yes, some folks whipped up on a 440 with their 383. Others whipped up on a 383 with their 340. Yep! In many instances, the 440 cleans house too. This would seem to indicate that a well matched engine build, a balanced drive train, a fresh tune-up, and someone who knows how to drive their car can easily break the gap to any advantage 40-to-60 cubic inches can have. But regardless of actual performance, the bragging rights the 440 yields always wins out simply because it’s the biggest passenger car production engine Chrysler built. Bigger is always better, right!?!?
Re: 383 VS 440
[Re: 67coronetman]
#1017191
06/25/11 11:37 AM
06/25/11 11:37 AM
Posts: 4,310 Prospect, PA
BSB67
Prospect, PA
Nice. What does it weigh, and what is the et and mph?
Re: 383 VS 440
[Re: CompSyn]
#1017192
06/25/11 11:50 AM
06/25/11 11:50 AM
Posts: 8,936 Holly/MI
Dean_Kuzluzski
Holly/MI
Everyone keeps talking about the bigger HP the 440 makes BUT it's the big TORQUE that moves a car better at a lower rpm that makes a 440 better.
Torque is king on the street. The short stroke 383 is more sensitive to its combo to really work, the 440 is more forgiving.
Re: 383 VS 440
[Re: HYPER8oSoNic]
#1017196
06/25/11 01:36 PM
06/25/11 01:36 PM
Posts: 21,814 Kirkland, Washington
Pacnorthcuda
Nothing like BB low end grunt rumpity rump. From the basement. 440. Otherwise you're just "explaining.
Let's look at this from the TOP(end that is). Nothing like the HI-RPM scream (6000rpm or MORE) going thru the gears. Rev to the stratosphere. That's the 383, baby! Otherwise, YOU'RE just all "TORQUE" (talk)!! And YOUR basement door slams shut AT 5-6000rpm.
A 440 will be two car lengths ahead of the 383 before it even gets to 5000 RPM!
And LOTS of 440's are pulling strong well past 6000
Re: 383 VS 440
[Re: Pacnorthcuda]
#1017197
06/25/11 01:45 PM
06/25/11 01:45 PM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
I know this is just rehashing most of the posts above but for a street bruiser with a set amount of money invested, and an equal build, in the engine the 440 will be the champ EVERY TIME. EVEN is the engines make the same peak HP (which they wont)
Area under the curve!!!!!!!!!!!!!!!
Contrary to your BELIEFS.... which HAVE some merit, SET COSTS are not part of this equation. YES, the 440 has MORE cubes which gives it a distinct COST advantage. There is less cash outlay and ingenuity to reach 500 hp. The 383, as I stated before, can reach this 500hp level, but due to the less cubes a "bit" more money spent in the right areas can net a VERY capable street/strip motor with great power. If it was a question of money spent or saved (main reason to go with the 440!!) then the 440 definitely GETS the nod. But a 500hp 383 make cost a little more, but can net you excellent performance. You want to toss 'em away, good, more for me to build and develop power on!!
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: 383 VS 440
[Re: CompSyn]
#1017200
06/25/11 02:55 PM
06/25/11 02:55 PM
HYPER8oSoNic
Desert Tracker
Bigger motor + less cash outlay to put in more power = winning strategy!! Nice formula!! But... sometimes it's not, depends on how well ANY given combo is put together (parts matching and TUNING)!!
