#1014240 - 06/16/11 08:43 AM 41 Plymouth Business coup / axle questions
funkyjbp Offline
mopar addict
Loc: Parsons (SouthEast) Kansas
Hey guys, JP in Parsons ks. I am buying a 41 ACP or ASC (?)coupe tomorrow. i refer to them as business coupes but it has jump seats instead of the cargo divider so i don't really know what it is. I ha ve a dakota chassis and good magnum 318/518 OD for it. What rear axles are you guys using? i am going to do the dak front clip but keep the stock rear frame sections. I've heard B/E body 8&3/4s are almost bolt-in. I can use a dak rear but i have sure grip third members laying around. I'll post pics soon. I'm getting it out of Oklahoma and was posted on HAMB. JP in the land of oz. 620-820-3793
71 SWB, 413 77 SWB, 318 92 SWB, 5.2 magnum 79 Macho Short bed, 318 03 stratus coupe R/T too many others not on the road!
#1014241 - 06/16/11 09:20 AM Re: 41 Plymouth Business coup / axle questions [Re: funkyjbp]
RodStRace Offline
Loc: Chino Valley
The dakota clip is a bit wide for the car, you will end up with FWD offset wheels on the front to clear.
If you have read here and the HAMB, you know a lot of guys with these suggest the shock relocation, dropped spindle and disc conversion for savings and ease. If you gotta have a clipped car, they seem to be the most commonly sold as half-done projects...
I used a 68 Coronet wagon axle, changed the spring perches. I have heard the later model Explorers work.
#1014242 - 06/16/11 12:54 PM Re: 41 Plymouth Business coup / axle questions [Re: RodStRace]
65rbdodge Offline
Loc: n.e. pa.
i have an 88 dakota clip on my 47 desoto. the rear i got out of an 79 ramcharger, its an 9.25 355 gears w/ 4.5"bp and is the right width.
#1014243 - 06/16/11 04:30 PM Re: 41 Plymouth Business coup / axle questions [Re: 65rbdodge]
RodStRace Offline
Loc: Chino Valley
#1014244 - 06/16/11 08:15 PM Re: 41 Plymouth Business coup / axle questions [Re: funkyjbp]
36PLYM Offline
Loc: Lithonia, Ga
Used 68 Coronet 8 3/4 on the 36. Bolted right up, perches were right on. Used original springs, blasted and coated.
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
#1014245 - 07/04/11 11:42 PM Re: 41 Plymouth Business coup / axle questions [Re: funkyjbp]
CrAzYMoPaRGuY Offline
Loc: Canada
8 3/4 rear in my '40... bolts in perfectly.
Well, NOW it does.
CrAzYMoPaRGuY
25,741 Registered Members
192,936 Topics
WIW: Stock LA Motor Connecting Rods
by vinnyd76
02/19/19 12:12 PM
What would win, road grader vrs MGB?
by GODSCOUNTRY340
02/19/19 12:03 PM
EMISSIONS CODE P0440
by moparsquid
02/19/19 11:30 AM
Brake calipers
by scottyb1955
02/19/19 11:17 AM
