Panhard Bar #1012969
06/13/11 11:01 PM
06/13/11 11:01 PM
Lithonia, Ga
3
36PLYM Offline OP
36PLYM  Offline OP
Lithonia, Ga
Anybody have info on a bracket to attach panhard to 8 3/4 center section? Maybe at the snubber location?
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Panhard Bar [Re: 36PLYM] #1012970
06/14/11 12:00 AM
06/14/11 12:00 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I would think you would want to attach a panhard bar to the carrier housing bolts. A simple 1/4" flat stock with an ear added to make the bar attaching point double shear, attached to three of the center section mounting bolts (you can shift towards either side for more offset, if you want) will be strong enough unless you really getting carried away. Keep the bar connection point as close to the top of the center section as possible, excessive height would not be your friend. Least that was what we did when we were dirt track racing. Gene
Re: Panhard Bar [Re: poorboy] #1012971
06/14/11 07:41 AM
06/14/11 07:41 AM
Lithonia, Ga
3
36PLYM Offline OP
36PLYM  Offline OP
Lithonia, Ga
That was my first choice but the bolts are to short even for 3/16 plate. Are those bolts pressed into the carrier? Thanks.
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Panhard Bar [Re: 36PLYM] #1012972
06/14/11 10:02 AM
06/14/11 10:02 AM
E
earlymopar Offline
earlymopar  Offline
E
Yes
Re: Panhard Bar [Re: 36PLYM] #1012973
07/07/11 09:38 PM
07/07/11 09:38 PM
blewbyu Offline
blewbyu  Offline
Here You Go
Re: Panhard Bar [Re: blewbyu] #1012974
07/07/11 09:38 PM
07/07/11 09:38 PM
blewbyu Offline
blewbyu  Offline
Here You Go 2
Re: Panhard Bar [Re: 36PLYM] #1012975
07/07/11 10:25 PM
07/07/11 10:25 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
One of the reasons a panhard rod isn't optimal is that it tends to move the housing side to side as it goes up and down. To lessen the effect you want a panhard rod to be as long as possible. I would attach it to the axle flange on the axle end if at all possible.
Or, if you want to eliminate the problem altogether, use a watts linkage.
Don't be the exception.
