Re: 1971 RR resto...
[Re: cdp]
#1012376
06/12/11 11:45 PM
06/12/11 11:45 PM
Posts: 3,691 MO
cdp
MO
[Re: cdp]
#1012377
06/12/11 11:46 PM
06/12/11 11:46 PM
Posts: 3,691 MO
cdp
MO
[Re: cdp]
#1012378
06/12/11 11:47 PM
06/12/11 11:47 PM
Posts: 3,691 MO
cdp
MO
[Re: cdp]
#1012383
06/14/11 08:50 PM
06/14/11 08:50 PM
Posts: 3,691 MO
cdp
MO
[Re: cdp]
#1012390
07/03/11 07:46 PM
07/03/11 07:46 PM
Posts: 3,691 MO
cdp
MO
[Re: cdp]
#1012391
07/03/11 07:48 PM
07/03/11 07:48 PM
Posts: 3,691 MO
cdp
MO
[Re: cdp]
#1012392
07/03/11 07:49 PM
07/03/11 07:49 PM
Posts: 3,691 MO
cdp
MO
[Re: Devil]
#1012394
07/08/11 07:00 PM
07/08/11 07:00 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
WOW, you are rockin' and roll'n on that thing. Looking good. Your splash shields look great. How did you redo them to look so nice? Media blast and dye/paint?
Joe
65 Barracuda 70 Challenger
[Re: cdp]
#1012405
06/23/12 10:25 PM
06/23/12 10:25 PM
Posts: 3,691 MO
cdp
MO
[Re: cdp]
#1012410
07/17/12 10:54 PM
07/17/12 10:54 PM
Posts: 3,691 MO
cdp
MO
[Re: cdp]
#1907768
09/07/15 12:28 AM
09/07/15 12:28 AM
Posts: 3,691 MO
cdp
MO
[Re: cdp]
#1908116
09/07/15 04:40 PM
09/07/15 04:40 PM
moparpollack
Lil Herman
Lil Herman
85086
Can't beat a red roadrunner!
[Re: cdp]
#1908180
09/07/15 06:51 PM
09/07/15 06:51 PM
Posts: 3,691 MO
cdp
MO
[Re: cdp]
#2148216
09/05/16 07:54 PM
09/05/16 07:54 PM
Posts: 2,592 None
71rm23
None
Bumpers are going to tri-city plating this weekend. What about the bumpers? I see you got them back but how did Tri-City do? I'm going to have them do mine as well.
[Re: cdp]
#2158075
09/20/16 01:14 PM
09/20/16 01:14 PM
Posts: 3,267 Connecticut
1972CudaV21
Connecticut
When do expect to finish your project? Looks good!
China is the enemy.
[Re: cdp]
#2957143
08/25/21 12:39 AM
08/25/21 12:39 AM
Posts: 572 Portland , Oregon, United Stat...
smokes
I went with 15x7's all around. 255x70s rear, 225 or 235 x 70's front. I started with 60's, but they seemed too small to me. 15x8.5's were too tight.
Hello, any update on this build ? hopefully you still have it and are done with it?
Looking for a clean w150 or w200 **72-80 body style In the Pacific Northwest**
[Re: 76Beeper]
#2963896
09/14/21 06:35 AM
09/14/21 06:35 AM
Posts: 3,691 MO
cdp
MO
Update: Got the RR out of storage this 9/11 weekend after about an 18-month hibernation. The 71 GTX engine rebuild last year got in the way. Working on some clutch problems and am actually going to get it prepped for a repaint. Too many flaws and some color die-back that bothers me. It is up and running. Sounds great with the CompCams XE274 cam. Anyone else have Mopar_ADHD that keeps them working on too many projects at once?
@76Beeper, yes, a 70 series should work fine on an 8" rim. I experimented with an American Racing TTO with the 255-70 on a 15x8.5, and didn't care for how the bulge was when inflated. It was really close to the wheel lip and just didn't look right, so the tire was remounted on a 15x7, and it worked great for me. My final tire is 255/70 rear, 225/70 front. My front clip isn't on yet, so its hard to see how it fills the wheel wells. The RR is equipped with 3.55 gears, but the drive ratio specs out to 3.23 with tall tire. Something to think about.
Currently, I have the same wheel set on a 71 GTX, same tire, but in 60 series and do not like the stance. IMO, the 70 series is the best combo.
[Re: rdrnr6970]
#2977982
10/24/21 08:18 PM
10/24/21 08:18 PM
Posts: 3,691 MO
cdp
MO
Got my clutch squared away. Turned out that the clutch fork bracket was slightly bent back a little, not allowing the fork to fully engage in the throw out bearing. I went ahead and replaced the side cover of the transmission with a fresh one from Brewers Performance, installed an improved adjustment ball assy. from later model MaMopar, and pulled the clutch spring from under the dash to work better with a diaphragm clutch. Now I have full correct adjustments and everything is new.
Decided that there are a few paint issues I'm not happy with. A bubble in the door corner, a few chips, and a few light spots where full coverage didn't happen. Plus I'm adding exhaust tips and a cut-out valance. So, it will receive a full repaint over this winter. The shop said that they would install and align all sheet metal and decals. So, hopefully, come spring she will nearly completed.
