Re: First run on the STREET! Oil pressure drops LOWat idle? [Re: DartGTS] #1010471
06/11/11 03:20 PM
06/11/11 03:20 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I do a 20min break in and drain oil and change filter. I had low pressure when idling and pitched the Fram. Problem fixed!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: First run on the STREET! Oil pressure drops LOWat idle? [Re: JohnRR] #1010472
06/11/11 05:38 PM
06/11/11 05:38 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
IS the rule of thumb 10 per 1,000 in relation to RPMs? Just found that on an on-line search
Yes it is , though that is a little low for a fresh build , what pump do you have ?
then why have a tach ? does Your oil pressure gauge leap around like a tach ? Mine stays at 80 when cold....goes to 65 to 70 when warm....40 at idle....and if I juice the motor it doesn't react to a 10 psi increase for every 1000 rpm.....My is this pressure per rpm is rubbish
Re: First run on the STREET! Oil pressure drops LOWat idle? [Re: terzmo] #1010473
06/11/11 05:50 PM
06/11/11 05:50 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
My 440 likes Amsoil 10-40. Slight drop off of peg after extended high speed driving.
