06 charger rear disc removal #1010008
06/09/11 03:44 PM
06/09/11 03:44 PM
IL us
I
ink Offline OP
ink  Offline OP
I
IL us
doing the breaks on my wifes 06 charger sxt disc is loose caliper is off and caliper mount e break seems to be holding it from coming off. was told from service station need to back the e break off but cant find nothing to back it off called dealership 3 times still no help says it should just pull off. oh and the factory assembly line hold on clips are off any help would be apreciaited
Re: 06 charger rear disc removal [Re: ink] #1010009
06/09/11 03:48 PM
06/09/11 03:48 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Typically rust builds up inside the park drum.Usually there is a small star adjuster inside the rotor.Try turning the rotor and pulling at the same time.Its like when you remove drums that are rusty on the liside lip.Most have a small plug to get at the adjuster.I havent worked on one of those yet but did thousands of rear discs with the same problem.Rocky
Chrysler Firepower
