Re: Build me a 1000HP 400ci NA engine...........
[Re: gregsdart]
#2622680
02/17/19 08:32 PM
02/17/19 08:32 PM
Posts: 4,101 Yes
sixpakdodge
Yes
rick watters has a set of the newer aussie heads and they are sprinklers as well,,,, there is no metal in the bowl area
i was going to have them cast here in the us with no labels or markings, then make plastic pieces which receive in where the labels and markings need to be
it would prob be 5k for a set of castings,, not enough demand,, so started thinking of a small inch 99 hemi
what matters is the timeslip,, not the dyno number,, guys say you loose 2 tenths and some mph going to a 10.5 tire,, i dont believe that if you can still go 1.17 or so 60 ft please empty your pm box Umm... https://www.legacy.com/obituaries/name/jeffrey-kobylski-obituary?pid=179074522
[Re: sixpakdodge]
#2622697
02/17/19 09:37 PM
02/17/19 09:37 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
what matters is the timeslip,, not the dyno number,, guys say you loose 2 tenths and some mph going to a 10.5 tire,, i dont believe that if you can still go 1.17 or so 60 ft please empty your pm box Umm... https://www.legacy.com/obituaries/name/jeffrey-kobylski-obituary?pid=179074522 To be fair Modern Cylinder Heads is still in business.
