Re: 220 air compressor wiring
[Re: hamerg]
#100933
08/06/08 10:19 PM
08/06/08 10:19 PM
Posts: 233 NH
Fastback67
NH
If your going to use a plug, use a Twist-Loc style plug and receptacle. Compressor vibrations won't cause it to loosen and fall out. If you hard wire to a shut off, try and get a shut-off that can be fused for added protection. Ideally it would be nice to have both... IE: A fused shut-off switch, supplying a receptacle. P.S. Any particular reason why your using a UF cable?
[Re: hamerg]
#100935
08/06/08 10:26 PM
08/06/08 10:26 PM
Posts: 22,696 Bitopia
jcc
Bitopia
50'+ on 10/2 running a compressor is OK, but heavier (8?) would be nicer on compressor, I don't care what the books say. Are you running anyting else off this 10/2 circuit, such as lights, outlets, etc? ( which means you will need a nuetral also) How much duty cycle will compressor be running?
[Re: Fastback67]
#100942
08/07/08 10:51 PM
08/07/08 10:51 PM
jcc
Bitopia
a 15 amp circuit, which means that it draws at least 20% less than that at start-up... unless he has reported it wrong
or you use a slow enough current measuring device to get the results you want. Whats the big deal with upping wire size one step at what cost, maybe $10, almost reduces all currrent/voltage issues, allows future growth, always can be sold for scrap, etc. I guess some follow the book, others write the book, and still some throw out the book. Oh Well. Where's that beaten horse thingy?
