Fuel tank pad #1008179
06/06/11 11:01 PM
06/06/11 11:01 PM
70duster340 Offline OP
Has anybody made their own fuel tank pad? If so, what type of material did you use?
Re: Fuel tank pad [Re: 70duster340] #1008180
06/06/11 11:22 PM
06/06/11 11:22 PM
USA
K
krw71ragtop Offline
krw71ragtop  Offline
K
USA
I used tar paper from the local hardware store. You will have plenty left over. I also use it on the out side of my deer blind.
Re: Fuel tank pad [Re: 70duster340] #1008181
06/07/11 03:48 AM
06/07/11 03:48 AM
Medford OR
FrankenScamp Offline
Medford OR
Tar paper here too. Doubled up for thickness. New pads are cheap enough but the roll of tar paper was there so I went for it.
Don't use anything that will absorb moisture. I bought my old Scamp that had indoor/outdoor carpet laid in there and it had rusted the tank through w/pinholes and rusted up the bottom of the trunk floor metal.
Re: Fuel tank pad [Re: FrankenScamp] #1008182
06/08/11 12:55 AM
06/08/11 12:55 AM
So, tar paper is the popular choice? I have a roll of that here, but it's several years old. There was no tank pad when I removed the tank, so what can I use as a pattern?
Re: Fuel tank pad [Re: 70duster340] #1008183
06/08/11 01:14 AM
06/08/11 01:14 AM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
Tar paper comes in at least 2 thicknesses. Use the thickest stuff, then you won't have to make it double layered.
Re: Fuel tank pad [Re: Steve340] #1008184
06/08/11 01:16 AM
06/08/11 01:16 AM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
tank
Re: Fuel tank pad [Re: Steve340] #1008185
06/09/11 11:06 PM
06/09/11 11:06 PM
Thanks, Steve!!!
