Page 2 of 3 1 2 3
Re: ProCharging my SRT Challenger [Re: FastmOp] #1007145
07/03/11 11:21 PM
07/03/11 11:21 PM
Mr440GSS Offline
Mr440GSS  Offline
I'd recheck your numbers. Your junk sounds like it should be makeing more power for the cash spent.
Good one, BUT, my junk was a 5.7 R/T.... Hows it feel to spend $10K+ for that extra 18HP on the SRT???
Enjoy those pistons while they last....
Re: ProCharging my SRT Challenger [Re: Mr440GSS] #1007146
07/04/11 07:27 PM
07/04/11 07:27 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
bigtime auto baby less then 7g's and out srt picked up over a second with no lose in drive ability
Re: ProCharging my SRT Challenger [Re: fishy340] #1007147
07/04/11 10:13 PM
07/04/11 10:13 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
I love the way it drives now, stock till you go a little too far then it hikes the front end and starts black tracking and barking gears lol
mine was under list by a bunch, and I installed it my self.
I would have liked to fattin it up till it stops making more power but it's alot safer now then it was is what I was wanting peeps to see.
I will be putting drag radials on it soon. My F1's are about done. TheN we will see what it puts on the time slip.
Re: ProCharging my SRT Challenger [Re: FastmOp] #1007148
07/04/11 11:36 PM
07/04/11 11:36 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
nitto drag radial work awesome on the 300,there pricey but so are stock 20" tires
Re: ProCharging my SRT Challenger [Re: fishy340] #1007149
07/17/11 12:30 PM
07/17/11 12:30 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
I'm looking at the new Weld wheels for this thing. Anyone one if a ten inch wide rim will fit. Also will a 295 series tire fit?
Re: ProCharging my SRT Challenger [Re: FastmOp] #1007150
07/17/11 02:27 PM
07/17/11 02:27 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
With slightly different offsets and backspacing, it seems like you can only fit about 9" in the front and 10" in the back.
Re: ProCharging my SRT Challenger [Re: Mr440GSS] #1007151
07/23/11 02:12 AM
07/23/11 02:12 AM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
18 HP??? Most SRTs dyno at about 360ish. 472 sounds like 112hp to me but maybe my math is bad.
If it is tuned to 13.2:1 AFR I really recomend adding some fuel to it. Those stock pistons have a very thin top ring land and burn through easily. Shoot for about 11.5. You will probably have to send the tune out and have it redone.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: ProCharging my SRT Challenger [Re: CW25] #1007152
07/23/11 02:18 AM
07/23/11 02:18 AM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
I think the issue here is identifying whether it was 472 at the crank or at the rear wheels. I am guessing the op meant at the wheels.
Re: ProCharging my SRT Challenger [Re: MuuMuu101] #1007153
07/24/11 01:42 PM
07/24/11 01:42 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
Yes my numbers are all wheel HP. I would like it a touch fatter as well but no more the mid 12's in A/F any more is just killing mpg.
On challenger talk there are people making well over 500hp on dynos and getting out run by stock R/Ts so I know dynos are for making sure your going the right way on the tune.
I have been thinking about a ten pound pulley
Re: ProCharging my SRT Challenger [Re: CW25] #1007154
07/25/11 01:00 PM
07/25/11 01:00 PM
Mr440GSS Offline
Mr440GSS  Offline
Please re read the thread... The OP was hammering on me because my car only made 454 RWHP vs his 472 RWHP... I only had the 5.7 R/T... So, in this case, he did spend an extra $10K or so for 18 horsepower and some SRT emblems vs my R/T...
Either way, the car is too lean and his tune is crap... He is going to break it. He doesn't want to fatten it up due to MPG??? Really?? Who buys a SRT and ProCharges it, and then worries about gas mileage?? Now he is talking about a 10 lb pulley...
Re: ProCharging my SRT Challenger [Re: Mr440GSS] #1007155
07/25/11 06:23 PM
07/25/11 06:23 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
How about you just go away! I'm happy with my car as it is. It makes more power then yours ha ha ha. Will always be worth more and will stop 100 times better. Your a joke.
Anything fatter then 12.5 is waisted fuel and is just as harmfull as not enough fuel. That unburnt fuel will lift a ring as fast as any other reason. Like I posted, if i could have went richer I would have, but to about 12.8 is all I care to see. But what do I know.
It's just over 1200 miles and a couple weekends at the dragstrip. It's still running fine at 8300 miles. I'll post again at ten thousand miles to see if it is still going. Lmao
Re: ProCharging my SRT Challenger [Re: FastmOp] #1007156
07/26/11 09:43 AM
07/26/11 09:43 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
here's me (11.93)on an easy pass vs my buddy's supercharged SRT-8. All I can say is learn to drive it before you go to the track and get some sticky tires. Otherwise be prepaired for 13 second passes.
http://www.youtube.com/watch?v=70nfYdOF-q0
Coming soon!!!!
Re: ProCharging my SRT Challenger [Re: Mr.Yuck] #1007157
07/26/11 10:48 AM
07/26/11 10:48 AM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
Your car sounds good!
I went 8.08 in the 1/8 last time out on the F1s it came with. I been waiting on Weld to get some wheels made then it's getting drag radials. Prolly won't go back till there on.
This challenger is my new muscle, The Valiant is my old Muscle. 541ci, Indy heads, Fast EFI. 1.29 sixty foot and 6.00 at 115mph footbreaking then there's an Avenger Im building from the junkyard up. Those are my main money pits. This Challenger is just my streeter I play with.
Re: ProCharging my SRT Challenger [Re: FastmOp] #1007158
07/26/11 11:59 AM
07/26/11 11:59 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Love the valiant!
Re: ProCharging my SRT Challenger [Re: FastmOp] #1007159
07/27/11 05:53 PM
07/27/11 05:53 PM
Mr440GSS Offline
Mr440GSS  Offline
no need to rag on my old Challenger as that car is long gone... Until Mopar makes a car that performs rather than an image car, I will have to live with new Brand X muscle....
So, I will leave you to your collector's item.... and tuning it like it is naturally aspirated... Please don't disable the knock sensors, I have a feeling that they are all that is keeping the thing together....
Re: ProCharging my SRT Challenger [Re: fishy340] #1007160
08/27/11 03:44 PM
08/27/11 03:44 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
put one on my dads srt 300 and did pretty well at the track..12.40's so it picked up over well over a sec..we want to put it on the dyno..to see if she's happy with the pro charge tune..he was in a rush to pick it up so
well went to the chassis dyno,and it says 400rwhp.. still picked up a sec in the 1/4 they say 370ish stock rwhp..a/f ratio looked real nice high 11's..but the chart also showed from 3500rpm to 6200 unstable climb not smooth like the beginning of the pull..were thinkin theres more left in it..just tryin to find a long island guy that knows what he's doing with the diablo..any suggestions?
Re: ProCharging my SRT Challenger [Re: fishy340] #1007161
09/13/11 03:01 PM
09/13/11 03:01 PM
NY usa
540challenger Offline
NY usa
There are not many tuners left out here. The only guy I keep hearing good things about is Brian at Kaltech. He mainly doesn GMs (LS motors) but if iam not mistaken he does everything.
http://www.kaltechtuning.com/index.php?main_page=index&zenid=cjski2ok1la70jnpffg2dn6p75
Re: ProCharging my SRT Challenger [Re: 540challenger] #1007162
09/13/11 04:19 PM
09/13/11 04:19 PM
Hot Rod Ridge
FastmOp Offline OP
FastmOp  Offline OP
Hot Rod Ridge
You have a ton left in it I bet. Prolly 50HP.
What were your a/f ratio? How many pounds of boost?
Procharged does a poor job of helping with a tune. It should be a lot closer then what they send.
Re: ProCharging my SRT Challenger [Re: FastmOp] #1007163
09/14/11 02:50 PM
09/14/11 02:50 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i couldn't agree more! today we are going to a tune guru here on long isl to correct pro chargers tune! puttin a set of stainless works headers on and guaranteed 500 rwhp..Chris longo has been getting a ton of pro charge cutomers from the co itself..ours made 409 rwhp and u can see the graph either ignition or timeing issue, either way the diablo tune is out the window! should have her done in 2 days..i'll keep u guys posted.
Re: ProCharging my SRT Challenger [Re: 540challenger] #1007164
09/14/11 02:53 PM
09/14/11 02:53 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
thanks 540chall well my bud went to that dude i believe and even went to vettedoctors they both struck out..thats when we got Chris longo..google him if u like cool dude and very good.
Page 2 of 3 1 2 3
