71 roadrunner air grabber hood *DELETED* #1006492
06/04/11 12:24 PM
06/04/11 12:24 PM
WASHINGTON
superbee471 Offline OP
WASHINGTON
Post deleted by superbee471
Re: 71 roadrunner air grabber hood [Re: superbee471] #1006493
06/04/11 06:24 PM
06/04/11 06:24 PM
MassHole Central
rtman Offline
rtman  Offline
MassHole Central
Re: 71 roadrunner air grabber hood [Re: superbee471] #1006494
06/04/11 10:20 PM
06/04/11 10:20 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
I assume you are using a Sat hood? There are already some of the holes there, vac hose clip holes for ex. After you get the big hole cut and the various bolt holes that are large and small, the nxt problem you'll run into is the mounting bolt holes for the actuator are not there and they were welded in in the factory. Take your time on this, I've seen it done a bunch of times.
Re: 71 roadrunner air grabber hood [Re: superbee471] #1006495
06/04/11 10:44 PM
06/04/11 10:44 PM
Shoreline, Washington
72roadrunnergtx Offline
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
