First i need to know if the wiring is correct in this master plug? Brown,Blue,Tan,Purple,Black,Pink,Red,Orange,Green,and Gray. I changed the white plastic that the wiring fastens in,I believe they are right but need another opinion. When I stared on this project of fixing my power windows a few days ago, my drivers side window worked,the left rear window was missing a motor,which i replaced. my master switch power is to Tan wire,all other switches power is on yellow. I have all switches plugged up and still no go. I have unplugged each motor and have tested them for up and down with a hot wire and a ground and they all work.It sounds like ground to me,but don't really know. the drivers side window was working off of master,and now since I changed plastic on master switch wiring, it is not working. Any help or good advice would be appreciated. I was wanting to install relays, but I have to get them working first. Thanks
