e body defroster and heater control question
#100473
08/06/08 12:21 AM
08/06/08 12:21 AM
Posts: 5,998 Salem
Grizzly
Moparts Proctologist
Salem
To pass a mechanical inspection, I have to prove that the defroster works on our car. The problem is, that the fan is blowing (not terribly fast) on defrost but the air is still directed at the floor.
You can hear a clicking sound when cycling the controls.
The car has factory A/C, so everything is push-button with vacuum lines.
Is there any way I can reach up in there to manually move the air control doors without pulling the whole thing apart?
Thanks!
Mo' Farts
Moderated by "tbagger".
Re: e body defroster and heater control question
[Re: screamindriver]
#100475
08/08/08 06:43 AM
08/08/08 06:43 AM
Posts: 21,063 Niles , Ohio
therocks
Niles , Ohio
You should be able to disconnect the vacuum and go into default mode.That makes the defrost work.All modern cars from about 69 have to have that.Its federal law.They want the defrost to work to clean the windshield.Like said it can be a vacuum pod or the cintroller itself.All modern cars push some air to the windshield always to keep it clean.Rocky
Chrysler Firepower
[Re: therocks]
#100476
08/08/08 03:48 PM
08/08/08 03:48 PM
Posts: 848 Avondale AZ
Prodart440
Avondale AZ
My 71 cuda hasn't had the vacuum hooked up in years. Blows cold A/C out the vents, not the defrost.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: Prodart440]
#100477
08/11/08 08:06 PM
08/11/08 08:06 PM
Posts: 5,998 Salem
Grizzly
Salem
Thanks for the replies.
I was able to pull out this vacuum pot and poked a screwdriver through the hole it came out of. The door flopped shut and now I have the defrost.
By the way, the only thing that held it back on the inspection was a crack on the outer rubber of the front brakeline. I was really fortunate that a close-by parts store couriered a brakeline from 2.5 hours away. I put it on and the car passed!
Mo' Farts
[Re: Grizzly]
#100478
08/11/08 08:07 PM
08/11/08 08:07 PM
Posts: 5,998 Salem
Grizzly
Salem
And, this is where it came from: directly above the map light.
Mo' Farts
