Re: 904 builders/racers... advice needed (long)
[Re: 340_Dart]
#1004716
06/01/11 10:37 PM
06/01/11 10:37 PM
Posts: 492 South Jersey, NJ
DragDart360
South Jersey, NJ
Would it not be less expensive to upgrade the engine than the trans? What are the engine specs?
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
[Re: 340_Dart]
#1004718
06/01/11 11:07 PM
06/01/11 11:07 PM
Posts: 2,404 Ambridge, Pa.
rickraw
Ambridge, Pa.
i'm running a, i think it's a 1971 904. 440 sb, 9.69@138.50. according to a&a, drum isn't a problem. billet low rev servo, red alto plates, harden strut, use teflon seal rings on support. line pressure is critical. should hold up with 180#, since 904 plates have a smaller surface area than a 727. i have a low 1st gear, 60'-1.30. stay safe, seeya.
[Re: rickraw]
#1004721
06/01/11 11:54 PM
06/01/11 11:54 PM
Posts: 1,745 Maryland
340_Dart
Maryland
I'm not saying the combination on the motor is perfect, but I doubt there's anything I can do to pick up .2 for the price of builiding a 904.
408 bottom end, steel k1 crank, k1 rods, diamond flat top pistons, factory block Indy 360-2 cnc heads, Indy intake converted to dominator flange. 1050 dominator 262,268@ .050 solid roller. .698 lift 10.3:1 compression. Pump gas motor
3000# race weight valiant 4.56 gear, 29.5x10.5 slick, ladder bar car 727 with transbrake, 5400 converter The only thing I think that would pick the car up would be to increase compression to 11-11.5 compression. However, with the Indy moved exhaust valve, there is no radial clearance on the exhaust valve relief...
[Re: DavidDean]
#1004722
06/02/11 12:06 AM
06/02/11 12:06 AM
dartman366
Mt. Vernon, Ohio
I also replace all the bushings and thrust washers, multi spring retainer as shown before, and I buy my kit's from Mancini, MRE 006 has the blue plates and kolene steel also a kevlar intermediate band (don't use it with a aluminum drum)use the 999 high gear drun and you will have to have the back of the pump machined for clearance, reenforced band strut and do the oiling mod's that I believe are in the tech section or the archives,, and also keep the line pressure up if you use the TA valve body it has only about 125# of line pressure, need to get that up around 150# or a little more, A@A has a spring you can replace on the VB that will up the pressure and greatly improve the action of the VB and clamps the clutches harder.
[Re: 340_Dart]
#1004724
06/02/11 02:47 AM
06/02/11 02:47 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Just use an early trans, so you don't have to deal with the lock up stuff which HP parts are limitied. You don't need the bigger drum from the 999. You can buy thinner discs and run 5 in the 904 drum. You will also need a shim kit to get proper clearance. And mixing parts is a PITA. Don't deal with that headache. Put good bands, clutches, and steels in. Get a Valve body from A&A, rebuild the trans, put in a blocker rod and put in a billet piston and 4.2 lever. I have nothing else done to my trans and I'm running it with a 7100 stall. 878 hp 563 tq... No trans brake though, so Rick may be able to recommend what else you HAVE to do. I have less than $800 in my trans besides the trick custom valve body Rick built me. I have 37 1/8 mile passes and 52 street miles on it. No issues and the oil pan shows no problems... Just my
[Re: dOc !]
#1004726
06/02/11 06:40 AM
06/02/11 06:40 AM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
Everything that needs to be said has already been said but I don't think you'll see 2 tenths, especially without the low gear. I think you'll be lucky to see .08.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: S/ST 3040]
#1004729
06/02/11 07:21 AM
06/02/11 07:21 AM
Guitar Jones
904 is 27 lbs lighter with 17 lbs of it rotating. Call Rick Allison at A&A.
4.56 gear and 29.5" tire?! Woohoo!
Yeah I know. I think they are worth more behind a small cube low torque engine, especially with the low gear set. Behind a large cube small block not so much. I know two guys, both big blocks, one is a Super Stock car and the other a Stocker. Both of them bought the high dollar ProTrans units and they didn't see but .15 at best and that could have been the weather.
I have a 904 in my car with the low gear but I went from a 4 speed to the 904 mainly because of the weight. Now I can tell you the low gear set really woke my car up when it was a 340 cube engine.
[Re: S/ST 3040]
#1004730
06/02/11 07:49 AM
06/02/11 07:49 AM
340_Dart
Maryland
Alright Vic, I gotta ask, what's the comment mean? Too much gear?
[Re: 340_Dart]
#1004731
06/02/11 10:18 AM
06/02/11 10:18 AM
Posts: 6,135 Melbourne , Australia
LA360
Big HP 904 I would run a 5.0 lever, but a 4.2 is the next best thing. 904's need the clamping force. 904's will break input shafts from time to time, but I would only worry about it when you actually break one.
Alan Jones
[Re: 340_Dart]
#1004732
06/02/11 01:18 PM
06/02/11 01:18 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
I think it's a little much but, at 131.5 MPH, you are probably less than 7200 RPM. I know Bill Hart runs the same tire and gear and Lonnie used to run 4.88's with 32" tire.
I guess I really can't point any fingers in the tire/gear department.
You definetly won't need the 2:74 1st gear! I don't.
[Re: S/ST 3040]
#1004733
06/02/11 04:18 PM
06/02/11 04:18 PM
Guitar Jones
I had 5.13's with a 29.5 tire with a 340. Shifted at 8000 went through the lights at 8100. But I had W5 heads too.
[Re: S/ST 3040]
#1004734
06/02/11 10:07 PM
06/02/11 10:07 PM
dartman366
Mt. Vernon, Ohio
mine actually went quicker with the standard 2.45 1st gear, unless you are way heavy and low horsepower then don't waste your time with it.
[Re: 340_Dart]
#1004735
06/02/11 11:18 PM
06/02/11 11:18 PM
Posts: 1,812 Portsmouth, VA
DusterW2
Portsmouth, VA
The best core to get is the 1975-1977 360 904 trans, which is a non-lock-up, wide 5 clutch front drum, and steel planets. You can upgrade to the 2.74 low gear set which are found in 1981-up 904's. This will allow a better launch without increasing the rear axle ratio. I would use Red lined bands that are solid backed, NOT flex bands. I have had good luck with the standard Raybestos Tan waffle clutches for high gear, with an upgrade to the Alto Red Eagles, www.altousa.com . Use the 2 spring front servo with at least a 4.2 lever. Use the 5.0 lever if you are really pushing a high pressure valvebody or using Nitrous. The 4.2 should work with most applications. Use a bronze output shaft thrust washer between the front of the output shaft and the rear of the forward clutch retainer. Set all end plays to minimum factory specs. Set direct clutch clearances to 0.010"-0.015" per disc or to the valvebody manufacturers' specs. The forward clutch clearance to 0.020" - 0.035", and use only FLAT selective snap rings. I would use the Griner 1222G20B transbrake w/ low band apply. You can install a shim in the low/rev servo piston to allow a better 1-2 shift. Most valvebodies have all these extras to aid the VB to better performance. I use the MP deep pan with drain plug and a good cooler. I also use Turbo Action converters with excellent results. I currently use a '73 core, 2.74 low, wide 5 clutch drum, T/A Cheetah valvebody, T/A 8" converter, deep pan, T/A Tranz Box rebuild kit. Rick Allison at A&A www.aandtrans.com is top notch and can provide any parts you need, and John Cope at CRT sells A&A parts as well. I would recommend 5 direct clutches no matter which drum you have. Use A&A thin direct clutches, P/N 12750A-6 if you have the standard 4 clutch drum. This will allow 5 clutches in the 4 clutch drum. If you have the wide 5 clutch drum, just use 5 Raybestos Tan waffle clutches. Also, concerning the front band, I would use the narrow center apply lug solid red band (kickdown, with grooves) on either the standard 4 clutch drum OR the wide 5 clutch drum. Normally, the wide drum gets a wider band, however, the apply lug on the band is offset from the center, and thus does not apply the band evenly, causing uneven wear, overheating, etc. In order to use the wide 5 clutch direct drum, you need a forward drum with input shaft from a non-lock-up trans. These will have an 1-1/8" wide splined clutch hub that fits into the direct clutches. The clutch hub for the standard 4 clutch direct drum has a 1" splined clutch hub on the front end of the clutch retainer. Also, you need a beveled back front pump reaction shaft support to clear the wider 5 clutch drum. You need to keep the years separated when swapping parts, 1975-77 or 1978+ all non-lock-up. The diameter of the sealing rings on the input shaft have a 0.062" difference between the two year groups and do not interchange. www.aandatrans.com www.coperacingtrans.com www.tcsproducts.comwww.727specialist.comThe 904 clutches have about 1/2 the surface area of a 727, so in order to live behind some serious torque, more line pressure is needed. 904 FLAT snap rings for clutch drums: (Mopar P/N's) 1942421 0.060" 1942423 0.076" 2538617 0.098" These numbers are old, and may be superceded to newer P/Ns. Ask your local Mopar dealer to check availability and price. If they don't have a way to order them, ask Rick at A&A, as he sells a kit with them. One required for each drum (2), and of the correct thickness to set clutch clearances properly depending upon which drum you are adjusting. In some cases, the snap ring will not give you the exact clearance you need. It is better to go a little loose than too tight. Also, A&A sells different thickness steel plates that fit between the clutch discs to help in zeroing in on the correct clearance. Another option is to machine the thick outer pressure plate a little if you have to. A machine shop should be able to grind the plate like a flywheel for a good flat surface after you figure how much needs to be removed. Remember, measure as many times as needed to be sure, and cut once. For reference, the snap rings that hold the gear train on the output shaft are selective, and are used to set gear train end play. These are the Mopar P/Ns: 06026289 0.041" 06030938 0.062" 06030404 0.084" Remember, always set the gear train end play and the input shaft end play close to minimum factory specs. The input shaft end play is adjusted by using a selective thickness fiber washer between the front pump and the direct drum. I don't have those numbers handy, but Rick would be able to help you with those as well. I mostly buy parts separately. I can buy a standard rebuild kit locally with Raybestos clutches, and I simply buy the performance solid red bands from A&A, CRT. They usually require a core to return as the solid bands are getting scarce. However, you can buy a complete race kit from either CRT or A&A. They can build to kit the way you want it. I have also bought from Bulk parts at a real good price, http://www.bulkpart.com At your power level and weight, you may need 300M steel input and output shafts. I would ask Rick Allison at A&A for his recommendation. Roller thrust bearings with steel planetaries may also be needed to ensure longevity. Aluminum direct drum may not be necessary in a 904 due to the smaller diameter and lower inertia, there is less probability of explosion. Main parts needed are a well designed high pressure transbrake to keep the small clutches and bands from slipping, good quality clutches and solid backed bands, pay attention to detail with clutch clearances and gear train & end play dimensions, and a rear roller support with oiling mods to the sprague and direct clutch oil port in the reaction shaft support. A multi-spring pack for the direct clutch to replace the single coil spring. John
[Re: DusterW2]
#1004736
06/03/11 03:32 AM
06/03/11 03:32 AM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
Your the man!
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
