68 383 cuda radiator? #1004644
06/01/11 07:55 PM
06/01/11 07:55 PM
ga
4-speed Offline OP
4-speed  Offline OP
ga
Does anyone have a picture of a original 4 speed radiator.thanks in advance
Re: 68 383 cuda radiator? [Re: 4-speed] #1004645
06/01/11 10:45 PM
06/01/11 10:45 PM
ga
4-speed Offline OP
4-speed  Offline OP
ga
Re: 68 383 cuda radiator? [Re: 4-speed] #1004646
06/02/11 12:40 AM
06/02/11 12:40 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's an 033 round top , same rad 4speed or auto trans .
Re: 68 383 cuda radiator? [Re: JohnRR] #1004647
06/02/11 03:57 AM
06/02/11 03:57 AM
ga
4-speed Offline OP
4-speed  Offline OP
ga
ok thats the one i have but the bottom exits directly in front of the oil filter is this right.
Re: 68 383 cuda radiator? [Re: 4-speed] #1004648
06/02/11 09:09 AM
06/02/11 09:09 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Yep that is right. The lower hose almost hits the oil filter and comes darn close to the strut rod. Make sure it is an 033, the 68 B-Body 318 radiator is 038 and I have almost been duped a couple times when the 8 was flattened to make it look like a 3! The lower bung is a little more to the left than the 033.
JB Rhinehart, Realist
A-Body's RULE!
Re: 68 383 cuda radiator? [Re: Rhinodart] #1004649
06/03/11 10:25 AM
06/03/11 10:25 AM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
don't have the 33 rad in my ss dart clone (wish i did) but my lower hose does hit the oil filter, so i cut a different piece of hose to put over the lower 1 as a protective sleeve that is between the hose and filter. dave
