all right,what am i missing here? #1004616
06/01/11 07:29 PM
06/01/11 07:29 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
ive been rebuilding the entire front suspension on my 61 newport.no manuals that old for torque specs.tie rods seem to be the same (40) in all my manuals,so i would assume this would be correct.on line the only thing ive found on ball joints is @ (120).problem here is if i torque to that,the castle nut is run too deep up the stud,and the cotter has no way of locking around the castle nut.what am i missing here? need some suspension help here.does anyone have in there archive some specs to help me out?any or all would be a big help.
Re: all right,what am i missing here? [Re: mcmopars] #1004617
06/01/11 07:39 PM
06/01/11 07:39 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
guys, i know ive asked before on these specs,if anyone in the mopar world has these,please share.
Re: all right,what am i missing here? [Re: mcmopars] #1004618
06/01/11 07:42 PM
06/01/11 07:42 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
A balljoint is tightened in a taper. It should be only a little bit from snug to real tight, and the castle slots should be the right height.
MAybe you are missing a washer, but I'd look very carefully at the parts and application.
Re: all right,what am i missing here? [Re: mcmopars] #1004619
06/01/11 07:43 PM
06/01/11 07:43 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
My torque spec is 'tight.' If you can tighten it until the whole nut is all the way past the hole for the cotter pin, there's another problem besides the torque spec--like the nut is too short or the stud is too long.
Re: all right,what am i missing here? [Re: FuryUs] #1004620
06/01/11 08:19 PM
06/01/11 08:19 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
what about washer location? new washers were supplied with the new ball joints.i assummed they went under the castle nut.would one go on each side of the spindle? i dont remember ,as it wsa a few weeks since i took it apart?
Re: all right,what am i missing here? [Re: mcmopars] #1004621
06/01/11 08:33 PM
06/01/11 08:33 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
washer needs to go on the boot side of spindle,not the castle nut side.which would limit the amount of depth.the light just came one.
Re: all right,what am i missing here? [Re: mcmopars] #1004622
06/01/11 09:21 PM
06/01/11 09:21 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Never seen a washer installed on boot side of knuckle. I would not do that. It goes directly under castle nut.
Re: all right,what am i missing here? [Re: buildanother] #1004623
06/01/11 10:08 PM
06/01/11 10:08 PM
Ohio
Todd Offline
Todd  Offline
Ohio
putting the washer between the boot and the knuckle doesn't let the taper of the ball joint stud seat in the way. put the correct thickness washer under the castle nut so the hole in the stud lines up correctly.
