Aftermarket Temp Guage and Performer RPM #1004455
06/01/11 01:52 PM
06/01/11 01:52 PM
Cambridge, Ontario, Canada
CUDAJAS Offline OP
CUDAJAS  Offline OP
I am preping a Performer RPM intake for installation on my 360 Cuda and there are far fewer holes available to the water passages then on my Torker II.
Anybody have any pics of how they mounted the sender for a aftermarket manual temp guage using that intake???
Thanks,
Jason
Re: Aftermarket Temp Guage and Performer RPM [Re: CUDAJAS] #1004456
06/01/11 02:23 PM
06/01/11 02:23 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
If you aren't using the heater use a heater hose fitting. Or drill out and tap a passage into the water passage of the intake. I recommend making sure that the temp probe on the sender be in flowing coolant and not in a T or a bunch of reducer fittings.
Re: Aftermarket Temp Guage and Performer RPM [Re: MoparforLife] #1004457
06/01/11 02:42 PM
06/01/11 02:42 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Here's where I put mine.
Re: Aftermarket Temp Guage and Performer RPM [Re: stumpy] #1004458
06/01/11 10:55 PM
06/01/11 10:55 PM
CUDAJAS Offline OP
CUDAJAS  Offline OP
Thanks guys.
Looks like I can make it work.
Jason
