Re: SB Edelbrock LA heads 304cfm@.600"
[Re: Brian Hafliger]
#1003490
06/08/11 05:03 PM
06/08/11 05:03 PM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
That engine with those heads made 621HP this morning on pump gas. TQ was 541. Roller cam, 10.9:1, 1050, TTI 1 7/8 x 3.5" header.
Brian Hafliger
#1003492
06/08/11 05:20 PM
06/08/11 05:20 PM
Quicktree
very nice I like the blacked out carb and valve covers.
[Re: LA360]
#1003495
06/08/11 08:31 PM
06/08/11 08:31 PM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
Yep, Jesel stepped up and helped us with the drive. It fits R3 blocks, but we fanangled it to work on a stock block with Meziere helping us with the water outlets so we could swap cams, and make adjustments easier and quicker.
Just ran out of time to make any more HP but I believe there is at least 5-10 more in it with porting the adapter and lash change but no time left...was a looooooong 2 days! Brian
Brian Hafliger
#1003496
06/08/11 08:34 PM
06/08/11 08:34 PM
Posts: 465 Oconomowoc, WI.
Cudahlr
Oconomowoc, WI.
Impressive Numbers! Can we have anymore details? Did you happen to test it with any other headers?
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp 1985 Harley Sportster Bobber 2006 Ram 2500 sport - The Cudahlr
[Re: FlyFish]
#1003498
06/09/11 12:43 AM
06/09/11 12:43 AM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
Well...it's going in a mag, so I'll be vague. We tried TTI 1 7/8 x 3" and 3.5" collectors, spacers, moved the cam around, lash, 3 carbs, timing. Father time was kickin' our but on this build and just ran out of time to try a different cam combo. Cam was in the 260's @ .050 and lift was mid 600's. OOTB 1000HP did very well against everything the PC 1000HP and PC dominator but the dommy was KING from 4000rpm to redline!
Brian Hafliger
#1003505
06/13/11 07:18 AM
06/13/11 07:18 AM
Posts: 20,600 in a cattle trailer down by th...
Guitar Jones
Oh man, everyone on the interweb knows a stock block won't take more than 600 horsepower.
Nice build and nice numbers. Hell some people were telling me I wouldn't make 650, and I have W5's and a tunnel ram. We'll soon find out though. Hopefully.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: mopster]
#1003507
06/13/11 11:54 AM
06/13/11 11:54 AM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
Itīs a 408 pump gas street engine with 10.7:1 CR, MP .590" flat tappet cam and 1.6 rockers
Looks like a nice build! Will this go on a dyno to be tuned,or straight to the car? I think it will perform pretty well once you get it all dialed in. Keith
