Need pictures of a forged crank #1003308
05/30/11 10:57 PM
05/30/11 10:57 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
I have a 67 440 that I was told had a forged crank, it has a forged crank dampner on it ( thin round dampner ) but this crank looks like a cast crank to me. It's been a while since I've seen a factory forged crank so I'm not sure if it is or not. Does anybody have a picture of a forged 440 crank? or know of an easy was to tell?
Re: Need pictures of a forged crank [Re: 73rrak] #1003309
05/30/11 11:34 PM
05/30/11 11:34 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Easiest way to tell is to look at the stamping line on the rod journals. The forged will be wide as shown here.
The cast will be a thin sharp line.
Another tell tale sign is the rounded unfinished look of the counter eights.
Like this....
A cast crank has a a more finished look with very sharp/clean edged and corners.
Re: Need pictures of a forged crank [Re: WILD BILL] #1003310
05/31/11 12:52 AM
05/31/11 12:52 AM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
I'll have to compare your pictures to my crank in the morning. I saw the small pits or rough surface on the journal and the weights and it looked to me like it was from sand when it was cast but I see the same pits on the picture you showed.
Re: Need pictures of a forged crank [Re: WILD BILL] #1003311
05/31/11 01:08 AM
05/31/11 01:08 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
this should cover it...
Re: Need pictures of a forged crank [Re: 1_WILD_RT] #1003312
05/31/11 04:17 PM
05/31/11 04:17 PM
dogdays Offline
dogdays  Offline
The dead giveaway on the 440 cast crank is the number "440" cast onto an edge of a crank throw, I think it is on the #1.
To me, the forged counterweights look like Lima beans.
R.
Re: Need pictures of a forged crank [Re: dogdays] #1003313
06/01/11 11:51 PM
06/01/11 11:51 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
Thank you everybody........ The 67 440 was a forged crank and it and the rest of the motor are at the machine shop
