37 Dodge truck RatRod radiator needed......... #1002441
05/29/11 09:07 PM
05/29/11 09:07 PM
Middletown , Ohio
DonnieLawson Offline OP
Middletown , Ohio
While my 68 Cuda is in Body Shop hell , I found this old beast to play with.
The radiator is from a 58 Cheby and is rotten & leaking
Wheres a good place to find a street-rod style radiator that will cool the 440 that power's the beast ?
Engine is stock , but hairy in this thing
Donnie
Re: 37 Dodge truck RatRod radiator needed......... [Re: DonnieLawson] #1002442
05/29/11 09:09 PM
05/29/11 09:09 PM
Middletown , Ohio
Middletown , Ohio
1 more pic.....
Re: 37 Dodge truck RatRod radiator needed......... [Re: DonnieLawson] #1002443
05/30/11 11:23 AM
05/30/11 11:23 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I would start looking at Summits radiators and fit the biggest one you could into it.
Also, you could do what I did helping a buddy cool his Chevy love with a 327 in it. We measured out the maximum space for a radiator, which side the outlets where on and hit the boneyards looking. We found on from a /6 powered A100 van that was perfect. Problem today is that most, if not all, modern cars use crossflow radiators and that will not work for you, no room.
Don't be the exception.
Re: 37 Dodge truck RatRod radiator needed......... [Re: Supercuda] #1002444
05/30/11 12:24 PM
05/30/11 12:24 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
There is also a guy here selling radiators in the race car section.
Re: 37 Dodge truck RatRod radiator needed......... [Re: RodStRace] #1002445
05/30/11 06:41 PM
05/30/11 06:41 PM
WI
W
wannadrag Offline
wannadrag  Offline
W
WI
Cross flow radiators also work if you stand them up.
Re: 37 Dodge truck RatRod radiator needed......... [Re: wannadrag] #1002446
05/30/11 09:03 PM
05/30/11 09:03 PM
Middletown , Ohio
Middletown , Ohio
Found some guys , I just gotta remove the radiator , take the grille shell off , mount the shell the way I think would look the best "rattest" then take some measurements .
Looks like Champion Radiator has some universal fit for street rode .
A 3 row is $220................ I could live with that if the measurements work out .
Donnie
Re: 37 Dodge truck RatRod radiator needed......... [Re: DonnieLawson] #1002447
05/31/11 12:24 AM
05/31/11 12:24 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Center the rad in front of the fan.....
Sucke to have it overheat with a new radiator...
Re: 37 Dodge truck RatRod radiator needed......... [Re: RodStRace] #1002448
06/01/11 01:59 AM
06/01/11 01:59 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Grill looks like it needs to come down atleast 6"
Re: 37 Dodge truck RatRod radiator needed......... [Re: 76dodgeboy] #1002449
06/01/11 03:17 PM
06/01/11 03:17 PM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
I have a Champion made 1932 Ford radiator in my 1931 Ford that the top bracket is half torn/broken off after only 600 or 700 miles on it. Just saw it when I got back from a roadtrip to Santa Maria on Monday. I feel lucky I caught it when I did, it's about to let go and could have flopped an ORIGINAL 1932 Ford shell and insert ($$$$) onto the freeway!!
It did keep the engine cool though!
Re: 37 Dodge truck RatRod radiator needed......... [Re: 76dodgeboy] #1002450
06/01/11 09:24 PM
06/01/11 09:24 PM
Middletown , Ohio
Middletown , Ohio
Grill looks like it needs to come down at least 6"
Yep , I was thinking about dropping it down , and angling it back toward the cowl at the top a little .
The old junkyard radiator in it is too tall , requiring the grille to be mounted too high..
I was hoping the Champion Rads weren't junk
Donnie
