37 Dodge truck RatRod radiator needed.........
#1002441
05/29/11 09:07 PM
05/29/11 09:07 PM
Posts: 229 Middletown , Ohio
DonnieLawson
Middletown , Ohio
While my 68 Cuda is in Body Shop hell , I found this old beast to play with. The radiator is from a 58 Cheby and is rotten & leaking Wheres a good place to find a street-rod style radiator that will cool the 440 that power's the beast ? Engine is stock , but hairy in this thing Thanks Donnie
Re: 37 Dodge truck RatRod radiator needed.........
[Re: DonnieLawson]
#1002443
05/30/11 11:23 AM
05/30/11 11:23 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I would start looking at Summits radiators and fit the biggest one you could into it.
Also, you could do what I did helping a buddy cool his Chevy love with a 327 in it. We measured out the maximum space for a radiator, which side the outlets where on and hit the boneyards looking. We found on from a /6 powered A100 van that was perfect. Problem today is that most, if not all, modern cars use crossflow radiators and that will not work for you, no room.
[Re: DonnieLawson]
#1002447
05/31/11 12:24 AM
05/31/11 12:24 AM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Found some guys , I just gotta remove the radiator , take the grille shell off , mount the shell the way I think would look the best "rattest" then take some measurements .
Center the rad in front of the fan..... Sucke to have it overheat with a new radiator...
[Re: 76dodgeboy]
#1002450
06/01/11 09:24 PM
06/01/11 09:24 PM
DonnieLawson
Middletown , Ohio
Grill looks like it needs to come down at least 6"
Yep , I was thinking about dropping it down , and angling it back toward the cowl at the top a little . The old junkyard radiator in it is too tall , requiring the grille to be mounted too high.. I was hoping the Champion Rads weren't junk Donnie
