Almost died today, 3 times
#1002380
05/29/11 08:45 PM
05/29/11 08:45 PM
Posts: 82 WA
GasHog72
WA
So I was having problems with Hedman headers on the car with the steering linkage rubbing on the tube. Also the ground clearance was becoming a issue with parking in gravel. I removed them and put manifolds back on. After running the exhaust pipe and almost slicing my thumb off (please wear gloves) I finished with a set of Flowmaster 40 series. I started it up and it sounded pretty good with a nice thumping. I pulled out of the garage and proceeded to drive down to the main road on post(Fort Lewis) causing numerous car alarms to be set off. Right before the stop sign i gave it just a little more pedal to get it up the incline and it went full wide-open throttle. I proceeded to stop it with full pressure on the brakes and it slowed down to a stop. I shut off the fuel pump and shut her down. I looked at the carb and the throttle cable popped out a little from the recess and was [Edited by Moparts - Family Friendly Site - Keep it clean]-eyed. That caused pressure to be put on the cable so it didn't return. I ignored everything that told me not to continue. I started it back up and idle was good. I made a left at the stop sign and cruised down the road with no issues. I got to the stop light and made a right and gradually gave it a little pedal. Screeeching of the tires told me that wasn't a little. The car proceeded to go 60 in a 40mph zone and i proceeded to go back to infancy. I shut her down quickly and coasted to the next right turn. Same thing again, stuck cable. I corrected it just to get her back home and it happened again without so much drama before I was finally home again. I disconnected the throttle cable and rummaged through some parts and resorted to a old style Chrysler clamp-on bracket for the cable. After some adjusting and double-checking I backed her out again and hoped I wasn't going to have a near-death experience. Nope that wasn't in the plan according to this possessed car. It revved up to 2-3000 and I braked in preparation for it. It then slowed back down to a idle. Any ideas? I've had enough near-death for today and don't want to try it again without being sure.
Re: Almost died today, 3 times
[Re: GasHog72]
#1002382
05/29/11 09:10 PM
05/29/11 09:10 PM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
a pic would go a long ways. whats up with the return spring(s)? if you experience a "run away" throttle situation, just click the key off one click. kills the motor, doesnt lock the wheel. you should also be able to check all this, at home, without even starting the car. stomp the pedal a few times, and go out and look. if it's hanging up, dont drive it, until it's fixed. the liability of knowing there's a problem, and continuing to drive, can cost you everything.
[Re: jbc426]
#1002388
05/29/11 10:38 PM
05/29/11 10:38 PM
RapidRobert
Yeah I'd say the kickdown cable is binding. Can unhook the accel pump rod to keep from squirting alot of raw gas in while you diagnose things in your driveway
[Re: GasHog72]
#1002390
05/29/11 11:16 PM
05/29/11 11:16 PM
Golden-Arm
Sunny South Florida
hard to tell from the pic, but it looks like the bar to the kickdown is binding slightly. where you have the rod bolted against the adapter, i used the stud from the original linkage, with the hairpin clip to mount the kickdown. i'll have to see if i can find a pic, as the ride is gone, but the smooth stud, threaded on one end (that i mounted in the adapter) and then i put a flat washer on either side of the rod where it mounted to the stud, held on with the clip, and i used a paired spring set (smaller one inside of the larger one, not side by side) and everything was/is free to move without binding. i'll see if i can dig up the pics. edit: here's a pic of the stud i mentioned. ignore the writing, was the only pic i could find quickly. i found the pic on this page, which has very detailed instructions on how to properly set up the edelbrock stuff, in your ride. http://www.bouchillonperformance.com/bpetkdcinstructionsnew.asp
[Re: GasHog72]
#1002396
05/30/11 12:18 AM
05/30/11 12:18 AM
Posts: 461 Detroit Michigan
stinger
Detroit Michigan
I do have that stud. Don't really like cutting stuff that is hard to find(not in your average store) but if that fixes the problem then that's what I have to do.
don't understand why you would have to cut anything. if you have the stud then install it where you have the bolt. you could also try a long bolt,two nuts and a few washers as long as the slide link slides freely back and forth with no bind.
[Re: GasHog72]
#1002397
05/30/11 12:23 AM
05/30/11 12:23 AM
Posts: 4,230 State of retirement
52savoy
State of retirement
The factory throttle cable is available from different sources... An E-body uses the same cable. http://cgi.ebay.com/ebaymotors/NEW-71-74...=item3a6645764dFrom what I see the kick-down plate(slotted) is touching the wrong end of the carb stud. It should be on the back-end that way when you give it gas it starts to put pressure on the tranny throttle valve right away. so even with the correct stud the tranny kick-down won't work right. need to adjust rod out or replace it with a longer one. I probably have it but seeing you need it now...
[Re: GasHog72]
#1002402
05/30/11 01:24 AM
05/30/11 01:24 AM
Golden-Arm
Sunny South Florida
i didnt cut mine, why i mentioned to ignore the writing. i mounted the stud, facing outwards, where you have the kickdown bolted. a "hairpin" clip on the inner groove, a washer, the linkage, washer and another hairpin clip, is what i did to make mine work. double springs, and i verified it all worked, and operated smoothly, and freely, before driving. small block with an edelbrock performer and linkage kit, basically the same deal as yours. i also used the factory throttle cable, with no issues on mine.
[Re: GasHog72]
#1002407
05/30/11 11:50 AM
05/30/11 11:50 AM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You need to get the proper throttle cable bracket. Look here: http://arengineering.com/throttlebracket/Tbracket/tbracketframe.htmlOnce you get that fixed we can help you get things sorted out. Step 1: get the correct throttle cable bracket Step 2: install said bracket Step 3: get back to us so we can help you get it working properly.
[Re: GasHog72]
#1002410
06/12/11 11:35 PM
06/12/11 11:35 PM
Posts: 893 Tustin, CA
pishta
Tustin, CA
3 piece is the way to go. much easier to work with than a rube goldburg cable setup in my opinion. you can alter the length (or where the stud contacts)of the slot with a set screw and nut, slide it to where the full kickdown is (push back with hand)and the throttle is WOT, and tighten.
12 Grand Caravan 06 T&C 02 T&C 96 Breeze 65 Barracuda "S"
[Re: StealthWedge67]
#1002413
06/13/11 07:14 AM
06/13/11 07:14 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I've always wondered why the kickdown linkage had that huge long slot on it with springs holding it forward when everyone says to hook it up so it's full back at WOT, and then lock it down.
to prevent jamming the throttle at WOT makes sense!
**Photobucket sucks**
[Re: GasHog72]
#1002416
06/13/11 02:30 PM
06/13/11 02:30 PM
Posts: 15,487 Florida
scratchnfotraction
make sure none of the carb linkage on the other side is not getting held up on the intake or carb base gasket. should check the butterflys and base gasket as well. the mount would have to be broken and engine lifting a good amount to stick the throttle at WOT...it can happen though are you sure that throttle cable is not frayed and sticking in the cable housing itself? some more pics would be nice
[Re: GasHog72]
#1002418
06/13/11 02:59 PM
06/13/11 02:59 PM
Posts: 82 WA
GasHog72
WA
[Re: GasHog72]
#1002420
06/13/11 10:06 PM
06/13/11 10:06 PM
Posts: 82 WA
GasHog72
WA
So I took the carb apart just now and guess what I found in the fuel bowl? Metal debris. small as a grain of sand but no smaller. just enough to....keep the needles from closing. Which would also explain why I had to adjust the idle a few times after this all started. Will update with the results. It is aluminum. not steel. One thing i didnt mention was the car tried to go through the garage over the weekend. Just trying to get it back in there at idle-low throttle and whoomp 4k. came within about 2 feet of the inside back wall. I checked everything after shut off and found nothing. No stuck throttle cable. This all tells me that it has to be whats in the fuel bowl right now.
[Re: GasHog72]
#1002422
06/14/11 10:20 AM
06/14/11 10:20 AM
70Cuda383
Marysville, O-H-I-O
debris holding a needle open isn't going to make you spike to 4,000 rpm. you need AIR to match that gas, or you go rich maybe stalling out if it's TOO rich and you flood it.
but, if you have metal everywhere, and the carb is starting to wear out, maybe the butter flies were sticking open because they're worn out?
I see nothing that would jamb open with the linkage you posted pics of.
