Re: A833 stuck in gear ...breaking news...
[Re: Pacnorthcuda]
#1002251
05/31/11 09:31 PM
05/31/11 09:31 PM
Posts: 2,724 541 slobovia
A990
541 slobovia
The 1-2 lever should be locked unless the 3-4 ball is exactly in the detent, and vice-versa. Check that.
That's exactly what happened. 3/4 locks out 1/2 and vice-versa.
Your 1-2 and 3-4 sliders (the big round groove that the ends of the shift forks fit into) should be able to slide back and forth.
Will check tomorrow (I got called in for an early shift, no progress today)
As far as lube, I would NOT use ATF, even thought some do. Get a 75w90 or 80w90 GL-4 (not GL-5) gear lube. GL-4's are hard to find unless you look at Synthetics. Most all are GL-5 (formulated for rear-ends and not real brass-synchro compatible.
I appreciate this truth, I have a 05 SRT-4 and didn't understand why the transaxle gets away with ATF-4. I forgot about the brass synchros
Redline makes a few, Pennzoil Synchromesh is good. Amsoil makes em too.
What about Royal Purple? There's a dealer here in town
[Re: A990]
#1002252
05/31/11 10:16 PM
05/31/11 10:16 PM
Posts: 43,112 Bend,OR USA
Cab_Burge
ATF type F,ATF4, Dextron-Mercon3 or any other atf is fine see the other post on ATF in a NP833 They came from the factory with ATF
