Trunk pan replacement #1001489
05/28/11 05:53 PM
05/28/11 05:53 PM
Third rock from the sun.
busboy Offline OP
busboy  Offline OP
I will need to replace the trunk pan, among other things, on my 70' Coronet. I see one and two piece pans available. I assume the factory used a one piece. Any issues with installing a two piece? This is not a number matching super car so I'm not worried about that, just wondered what was correct.
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: Trunk pan replacement [Re: busboy] #1001490
05/28/11 06:34 PM
05/28/11 06:34 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
2 piece is fine if you install it well and finish center seam,for factory type 1 piece you will need to take rear body panel off to install
MOPAR OR NO CAR
Re: Trunk pan replacement [Re: hemigod426] #1001491
05/28/11 06:43 PM
05/28/11 06:43 PM
busboy Offline OP
busboy  Offline OP
Thanks, that's just the kind of thing I wanted to know. Tail panel is good, so not too keen on removing it Anyone else?
Re: Trunk pan replacement [Re: busboy] #1001492
05/28/11 08:02 PM
05/28/11 08:02 PM
IMGTX Offline
IMGTX  Offline
How is the lip near the tail panel look?
Often the lip gets rusted out. If so, see if the trunk pan goes all the way to where you need. It should but should and do are different things.
All manufacturers should be the same but check anyway to see if the lip meets your needs on both pans.
Re: Trunk pan replacement [Re: IMGTX] #1001493
06/01/11 11:06 PM
06/01/11 11:06 PM
busboy Offline OP
busboy  Offline OP
Ok, thanks, I'll check it
Re: Trunk pan replacement [Re: busboy] #1001494
06/01/11 11:27 PM
06/01/11 11:27 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
I put a two piece in my GTX, it looks and fit pretty good.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Trunk pan replacement [Re: rattler] #1001495
06/01/11 11:41 PM
06/01/11 11:41 PM
S.E. Missouri
AeroMonte Offline
AeroMonte  Offline
S.E. Missouri
I did a one piece on the 70 Charger I'm doing. The tail panel will have to be removed to do that one. A two piece will be a little more forgiving as you wiggle it around to fit. It will just have an extra welded seam down the middle.
