Fan Shroud Info
#1001162
05/28/11 12:54 AM
05/28/11 12:54 AM
Posts: 59 Rhode Island
Caparco
Rhode Island
I have a 72 challenger.. it had A/c but was takin out its a 26" radiator but it has the 2 bolts on the right closer together then the left side, they are not even distance all 4
YearOne tells me they don't have the right shroud for it, and some Challengers were made .. simply without a shroud!
Is this true? My radiator seems to blow leaks alot, and the shop that welds it tells me to get a shroud.. makes all the difference in the world.. is this true as well?
who has the challengers with the simple even 4 bolt radiators?are they 26"? Thanks for help + Info + advice Marc
~ 72 Dodge Challenger ~ ~ 97 Dodge Neon ~ ~ 97 Dodge Ram ~
Re: Fan Shroud Info
[Re: radiatorman]
#1001166
05/28/11 10:59 AM
05/28/11 10:59 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I find it hard to believe that they would ship them WITHOUT a shroud from the factory...
there's got to be something out there that fits a factory radiator. if yours isn't factory, and the bolt holes aren't correct, then maybe you can fabricate one?
**Photobucket sucks**
Re: Fan Shroud Info
[Re: cuda-sweden]
#1001168
05/28/11 02:47 PM
05/28/11 02:47 PM
Challenger 1
Cincinnati, Ohio
-70 cuda with 26" radiator and ac,the shroud is still sold by mopar.i think the part,nr ends with 326.maybe thats the one you need?but that adding a shroud should stop the radiator from blowing leaks?
I don't think any challengers left the factory without a shroud. These shrouds will fit any 26" mopar radiator and other 26" radiators also. Yes it's true what your radiator shop told you about needing a shroud.
Should still be able to get them from Mopar.
Re: Fan Shroud Info
[Re: Challenger 1]
#1001170
05/28/11 02:53 PM
05/28/11 02:53 PM
Caparco
Rhode Island
challenger 1 does that shroud have the smaller drivers side holes.. 11 1/2.. or are they both 14" from each other?
Re: Fan Shroud Info
[Re: Challenger 1]
#1001172
05/28/11 10:51 PM
05/28/11 10:51 PM
Caparco
Rhode Island
make a bracket?.. sure i can just duct tape it on there too and make it fit, problem is if my Challenger has this (un-even) bolt set up, im sure a whole line of others had the same and the shroud that fits should be around somewhere
No?
Re: Fan Shroud Info
[Re: Caparco]
#1001173
05/31/11 10:02 AM
05/31/11 10:02 AM
Caparco
Rhode Island
Sorry guys.. I thought the shroud bolted up with the radiator bolts! now i see the other bracket , its just on the "inner" part of the radiator only.
I didn't know cause I never had a shroud here to see it. there 26" accross and 12 3/8" up and down and all for even im sure thats what that part # is
the holes are not threaded though.. just a punched hole, are there special screws to attach this shroud , does it come with it?
