Re: 2.4 water pump job?
[Re: 440newport]
#1000965
05/27/11 09:00 PM
05/27/11 09:00 PM
Posts: 12,415 Kalispell Mt.
HotRodDave
Kalispell Mt.
yes.
It is driven off the timing belt so you have to pull it off and you might as well replace it while your in there. Even to get it off without replaceing the belt you need to pull the crank damper, you need a 3 jaw puller. You have to pull the damper to pull the cover to get at the stuff in there. All data calls for 3.8 hours, the first time I did one it took me twice that long, now after doing a few I think I can get that time.
[Re: rallye73]
#1000970
05/27/11 09:50 PM
05/27/11 09:50 PM
Posts: 4,587 St. John's Newfoundland
440newport
Helps to gain access from up top to work. The Stratus is more of a PETA to work on than a Neon. There is very little room next to the strut tower.
Yes, There's very a little room between the engine and fender. I can see this being a busted knuckle swear fest.
Do I need a manual to do the timing procedure? or are there clear marks on the sprockets and block where everything should line up?
[Re: ralphie361]
#1000973
05/28/11 12:52 AM
05/28/11 12:52 AM
HotRodDave
Kalispell Mt.
Whenever I have a good running engine I am about to do a t-belt on I always mark the belt and pullys where they are, then I take them off and transfer the old belt marks onto the new belt, then install the new belt and line up the marks on the new belt with the marks on the cam and it is done, fool proof if you are carefull.
