Re: transmission cooler hard line substitute
[Re: Commando1]
#1000705
05/27/11 10:47 AM
05/27/11 10:47 AM
Posts: 18,157 Mass
DAYCLONA
Mass
You'll get a lot of answers that border on "ghetto repairs", but other than steel tubing, the ONLY route I would take for flexible lines is braided steel with AN fittings. My 2¢...
......I would second that statement, except to specify that the braided stainless hose are just that, ALL stainless construction, hose as well as sheath, no rubber hoses with braided SS sheath...
If you have access to McMaster Carr, you could order your flexible ALL stainless hoses, made to size, and end specfications
[Re: dOc !]
#1000711
05/27/11 05:46 PM
05/27/11 05:46 PM
Posts: 616 TP Exit 7, NJ, USA
DANA60
TP Exit 7, NJ, USA
... GHETTO .....
THEN on the other end of the scale .... braided steel with AN's ...
MUST be nice if you have a boat-load of cash BURIED in the back yard ...
I have used NUMEROUS times ... some 3/8 alum tubing with some high quality braided black rubber hose.
Wanted to mine with braided, local race shop caries it all, it was $150.00 to do it that way, I think I'll bend mine too. Oh, by the way, it's 5/16 line.
[Re: Joesixpack]
#1000713
05/27/11 11:29 PM
05/27/11 11:29 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Year One has pre bent stainless steel and mild steel trans cooler lines listed for most A,B,E bodies, 904 and 727 trans, big and small blocks, $59 to $89......however i tried to order some today and they said 1-4 weeks....wonder who else has them? fine lines? Mega parts?
Order directly from FINE LINES,....most of the mopar 2 pc line kits are $45 for the 904/727 SmBlk/BBlk.....any of the aux cooler/HEMI kits run $115,.....Hard Stainless Tube is also avaliable for a few $$ more
