Checking Rod Bearing Clearance (BB)? #1000568
05/26/11 11:05 PM
05/26/11 11:05 PM
People's Republic of Kali
70runner Offline OP
70runner  Offline OP
Using plastigauge to check 440 mains showed .001 on #1, #3, #4, somewhat less on #2 and #5. Yes, I painstakingly cleaned the journals with acetone and read the english side of the plastigauge paper. Hauled the block/crank to the machine shop. They mic'd the crank journals, transferred the measurement to a dial bore gauge and measured between 2.4-2.6 thousandths clearance on all the mains. All is good.
Now I have to tackle the rod bearing clearance and am leery of using plastigauge, plus I understand torquing the rod bolts can distort the plastigauge readings. Are there any alternatives short of buying an expensive dial bore gauge?
Re: Checking Rod Bearing Clearance (BB)? [Re: 70runner] #1000569
05/26/11 11:39 PM
05/26/11 11:39 PM
Happy Birthday RapidRobert  Offline
rod at BDC, plastigauge ~1/4" off to either side from dead bottom, strips of feeler gauge on either side of rod to keep it square while torquing
Re: Checking Rod Bearing Clearance (BB)? [Re: 70runner] #1000570
05/27/11 12:33 AM
05/27/11 12:33 AM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
have both rods on that journal of the crank when checking with plastigage. It seems to make a difference, I think it can smear the wax if the other rod isn't there.
Re: Checking Rod Bearing Clearance (BB)? [Re: 70runner] #1000571
05/27/11 12:41 AM
05/27/11 12:41 AM
California
court9155 Offline
court9155  Offline
California
For some reason nearly everytime I checked plastigage against my mics it measured tighter with the plastigage then the mics.
I quit using it.
Dan
67 charger
