Anybody seen or used these? http://www.jegs.com/p/TICU-Racing/TICU-Racing-Full-Flow-Air-Screen/1566809/10002/-1
I'm wondering whether something like that would prove effective enough for track-only use (i.e. swap from regular air cleaner to this w/ a plate attached to seal the screen to the scoop) to provide some additional space between the carb and hood and free up my options for intakes to run w/ the Victor heads. Considering I've been using a 3" drop-base air cleaner, it's also not clear how much actual space above the carb this would add in comparison.
I really don't like the idea of running w/ no air filtration system at all on the track. However, I'm not sure how much this will do beside stopping birds, wayward children, rocks kicked up by cars ahead of me in the burnout box, etc. Maybe that's enough for just making passes down the 1320.
Oh, I also think they're HORRIBLY expensive for what they are.
