Quote: Are you planning to weld the perches to the axle? Im glad to here the shock plates can still be used instead of hitting the jy fo car ones but I still might
You can use the stock plates, but will begin to squeak over time because the plate isn't located to te center pin on te spring. I did this same thing on the first one that I lowered over 20 or more years ago. I drag raced mine & made the axle slide forward on the springs because it was only located on one side of the pin.
