Quote: I sure don't but the chebbie flip kit Ive used fit a 73-87 1/2 ton. It's a U-shape that fits under the axle & sits on top of the spring like the perch does. It fits into the stock perch from the bottom side.
Oh I see......wont need that I have a disc rear end from a 74 imperial...perch is all ready under the axle as oppose to the top like the truck. Thanks
