I level the truck with stands using shims to get it perfect & measure pinion angle with an angle finder before I flip or move spring hangers. I use the same measurement when I reset my angle. On drag vehicles I set the pinion 2-3 degrees lower to deter spring wrap up. Shims can be bought from various places who sell custom suspension parts Comp Engineering etc
