One thing I have found though is that a lot of the 70s Vans had standard non-pocketed control arms. 80s though the majority I have seen are pocketed however. The standard ones do have both sets of strut rod holes drilled.
What I have learned over the years was that 5 lugs or 8. As long as the lug stud diameter was 1/2" the ball joint is the same on the van. Big stud 3300# & larger requires drilling the spindle to bolt it correctly to the steering arm. As soon as I sit my RC on the ground again I'll post a pic of it & my lowered CrewCab. Kevin,I think your post is cool especially being this subject comes up very often.
