2011 Charger HO 3.5L. Got a bad odor of what smells mostly like unburnt fuel or partially burnt exhaust that is finding it's way in the cabin on warmer days when the car is idling with the A/C on. It's pretty bad actually and unquestionably something that is making it's way inside the car.
It only seems to happen on warmer days during the afternoon hours when the temperatures get up to around 70+ degrees. And even though I only notice it when the a/c is on in the car, I can smell it when I first approach the car from the outside before I even open up the door, then it is equally as strong on the inside (if the car is idling for several minutes). Once I turn off the a/c it still kinda radiates around the outside of the car when standing close on the outside?
Anybody else have this problem or has Dodge issued anything on this yet?
