Well I started a post on the South Chrysler Assembly Plant being torn down. https://board.moparts.org/ubbthreads/show...part=1&vc=1
This is a post on the removal of the North Assembly Plant.
The North plant assembled over a million Dodge Rams.
http://www.autospectator.com/cars/chrysl...llionth-dodge-r
The plant was closed for good in early July 2009.
Chrysler has implemented an early idling of the St. Louis North assembly plant. With this change, the Dodge Ram 1500 Regular Cab, which was previously built at St. Louis, will now be built at Saltillo, starting with the 2010 model.
Lets see some Rams that were built at the north plant.
I will be posting some pictures of the progress.
