Quote: Starting to work on installing the Grille tonight The new one fits OK but will need some finessing to resolve some fitment issues.
Still working on the front end. Here is a lesson learned, prefit your parts prior to painting. For some reason the original lower valance had the lower flange that the lower grille bolts to slightly bent and I could not install it without making some adjustments and some paint touch up.
