Quote: There is no center support. There is about an inch of clearance around the gas tank so there should be no rattle. This is an OEM panel I stripped and smoothed out. The body guys then fixed what I did and mounted it for me. Craig
Thanks Craig for the pictures. From what Im finding out the only year that used the bottom holes in the valance was 1970. The bracket was very unique and tied into the rear support then into the bottom valance holes on each side of the gas tank.. Thought they should have changed the design and eliminated the holes in the valance once the brkts were no longer used
