Fuuuudge
I hate bashin people , but jn this case i will .
Had Fireball tranny in Canada build me a
Tranny . First time around used the wrong
Clutches with an aluminum drum , drum toasted .
And tranny leaked like a sieve ..
aND Found a crack in the case after hours of
Strainful checking .. Sent him pics
He DID rebuild the tranny . Never thought to look
At the case ... He used the SAME one ..
Had DaVe D hook me up with Godfather
Racing , i have a correct killer tranny now ...
Are you sure you have to pull it ,
Did you start it in neutral to get all the juices
Flowin ?
All the linkage right etc etc . That's odd
That a new tranny slips .
I dont know much about the valve bodies
And passages and all that , but check and double check
Before yankin it . Deep pan ? No filter extension extension ?
