I have been perfecting a recipe to remove rust with minimal metal loss using simple household stuff and I finally got it right ! and I thought I would share with all of you!
the best mixture I have made so far is as follows:
1/2 gallon of white vinegar
1/3 cup of salt
1 of those yellow squeeze lemon juice bottles.
which I think are around 6- 8 ounces "realemon" lemon juice
I have tried countless combos over the past year!!
This combo just seems to work the best! and you
can reuse it and reuse it!
All you have to do is soak it for a minimum of 12 hours or longer if the rust is deep.. and it comes off like mud !! I used a generic scotch brite pad to get some of the hard residue off and the parts come out looking like they were sand blasted ! Plus it costs less than 5 dollars a gallon to make!
I attached pics of my results my cell phone is taking fuzzy pics right now and i will try and update with some better pics!
