you can check if ballast is defective if when cranking the BRAKE light cluster cames off. If dimms when cranking, ballast works. If brake light cames off, then ballast or a related plug or wire is damaged.
Do U mean goes off? What i did do was pull the dist out of the block and with key on i spun the rotor by hand and I had the most brightest blue spark at end of coil wire!put it back in the block and it only sparks once when key is turned on then once when u turn it off.. We tried two different ballast resistors ETC, has a new dist and a new ign box too, Now if the tach wire isn't hooked up from the coil would this be the problem?
