If they wanted the entire steel A pillars, door jambs, trunk surround, etc then thats what the rules should state. Not steel 1/4's and roof. How much can be removed? The outer skins dont weigh much w/o the factory structure. How many of these cars have the inner roof structure, rockers dutchman supports? Rules are made to be stretched to the limit. That is the case here. Doug
