If you're going to weld on the K make sure to run a bead or two around the lower control arm tubes, but be sure to grind back the welds on the back side where the pins go through so the control arm pins sit at the original depth. I've seen more than one A body Mopar that has cracked and broken those crummy welds and ruined a k frame by not addressing it in time.
