Me getting into my work (good to know a body fits in there )
Trunk floor is pretty clean, but I found some rust and scale under the excessive factory? seam sealer
I could only think of one easy way to clean up the area, I removed the jack bracket. The spot weld had ceated a hole that they had plugged with the seam sealer. I should have drilled the hole larger on the side
