Cloning a 1971 Cuda Convertible you will need the rocker trim, door and quarter window trim on top of the door and quarter, rear panel trim four pieces and all is coded on a CUDAs fender tag and broadcast sheet. Also the louvers for the fenders. You will have to weld in the proper studs or use the body repair studs for all trim.
1971 HEMI E BODY REGISTRY
