Originally Posted By AndyF
I had to make my own shock plates so I could get the lower mount in the correct location. For example, if you want 2 inches of compression and the rest for extension the lower mount needs to be located in the right spot. I couldn't find shock plates that did the trick so I welded up my own.
Nice work Andy.
Don
