Thinking of using a Ram air box setup on my 68 Charger with the stock flat hood.
http://www.ramairbox.com/
These air cleaner assemblies are sealed and use 4inch hose. My question centers on the inlet location. I'm thinking of running the inlets into the inner fender where air would be drawn in around the front wheels.
Obviously there is no ram effect but I'm wondering if it would be worth the effort vs the current setup which is a standard 14x3 drop base assembly.
Opinions ? Comments ?
Ron
