Originally Posted By DAYCLONA
Originally Posted By DaytonaTurbo
Sounds like the passon OD gear set would go a good option and be the closest to fit in your budget and be totally stock-fitting. The .8 OD ratio is a bit of a bummer though.
with a .80 OD, it's not even worth the effort or expense for so little a gain IMHO, besides the fact the OP never alluded to any indication if his car was already 833 equipped?
Yeah the car is a 1968 Charger factory 4speed 383 car so I really didnt want to alter the shifter hump in it.
Basically it wouldnt bother me to alter the trans crossmember but I didnt want to alter the cars sheetmetal on the trans tunnel or the shifter hump itself.
The Passon .80 ratio OD gearset is really not even worth the trouble as it wouldnt drop the RPM by much at all.
