Originally Posted By DaytonaTurbo
Sounds like the passon OD gear set would go a good option and be the closest to fit in your budget and be totally stock-fitting. The .8 OD ratio is a bit of a bummer though.
with a .80 OD, it's not even worth the effort or expense for so little a gain IMHO, besides the fact the OP never alluded to any indication if his car was already 833 equipped?
