I can get you either T56 Magnum or TKO transmission for way less than the big name Elite Tremec dealers. I am a new Tremec dealer and a Veteran owned small business and have a reference from Tremec themselves. I personally have a T56 Magnum close ratio in my Cuda and would never use anything else.
Both units will require cutting. There is modified TKO600RR designed to fit better due to the revised shifting position but it shifts worse and cost more that the T56.
I can also get Quicktime bells for Big & Small Mopar/Gen3 Hemi as well as Mcleod flywheels and clutch kits.
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
