I have it farther down, in the 14+ range, just turns the screws farther out.
I'm just going to live with it. There are other things that need attention, this is just more of a nuisance than anything else.
I didn't expect it to take this much time and energy, but since it is what it is and doesn't harm anything, it's good enough.
If you have a large overlap cam you should be focusing on idle quality, not what an O2 meter is reading. It simply does not read right. If the O2 meter is reading 15:1 the the combustion charge AF ratio could still be far too rich. Some have reported as high as 18:1 meter reading at best idle quality w a big cam
